Modbus TCPIP Configuration
2023-05-06 09:11
What energy storage inverters support Modbus TCP/IP function?
Product series and ARM versions integrated with Modbus TCP/IP functions:
Product Series |
Model Name |
MODBUS TCP/IP |
Compatibility |
Firmware |
SolarGo Version |
ET |
GW5K-ET/GW6.5K-ET/GW8K-ET/GW10K-ET/GW5KN-ET/GW6.5KN-ET/GW8KN-ET/GW10KN-ET |
ARM 25 or higher |
5.1.0 or higher |
BT |
GW5K-BT/GW6K-BT/GW8K-BT/GW10K-BT |
ARM 25 or higher |
5.1.0 or higher |
EH |
GW3600-EH/GW5000-EH/GW6000-EH/GW3600N-EH/GW5000N-EH/GW6000N-EH |
ARM 25 or higher |
5.1.0 or higher |
EHB |
GW5000-EHB/GW6500-EHB/GW8600-EHB/GW0010-EHB |
ARM 25 or higher |
5.1.0 or higher |
BH |
GW3k-BH/GW3600-BH/GW5000-BH/GW6000-BH |
ARM 25 or higher |
5.1.0 or higher |
Note: If a firmware upgrade of the inverter is required, use the SolarGo App and a Bluetooth module for a local update or contact GoodWe’s local support teams.
What communication module needs to be connected to support Modbus TCP/IP function?
Modbus TCP/IP is supported by connecting WIFI+LAN module to the inverter. Usually, the WIFI+LAN module used for MODBUS TCP/IP is not included with the inverters and needs to be purchased separately from GoodWe’s distribution channels. It replaces the existing WIFI modules of the inverters.
Note: there are different WIFI+LAN modules, and the one with USB terminal is compatible with the inverters listed here. Please refer to the table below.
Model Name of inverter |
Compatible module |
Wi-Fi/LAN Kit (USB terminal module) |
How to configure the Modbus TCP/IP via WIF+LAN module?
Here are the steps:
First: Install the WIFI+LAN module and connect the internet as the following linked guide shows.
GW_WiFi Configuration Instruction-EN.pdf (goodwe.com)
SECOND: Activate the Modbus TCP/IP function in the SolarGo APP.
Third: Wire the WIFI+LAN module as the below picture shows.
Dear User,
